WLAN Problem
0 replies · 5,375 views · Started 13 October 2008
I just upgraded my N95 8GB firmware to Version 30.0.018. Now there is a very weird and annoying problem. When I select an access point and connect to it, the little clover icon appears in the upper right corner showing that I'm connected but that's it. So I go to to WLAN again and I click Start Web Browsing and I am prompted to the list of access points to connect to again. I select the one I am supposedly connected to and it starts trying to connect again and then the error message comes up: "WLAN: WLAN connection already active. Close it and try again." I am connected but I cannot do anything to actually start browsing or use the internet. I cannot even disconnect from it....
Please let me know if any of this happened to you when you upgraded your firmware or have heard of this issue before.
I am thinking of reinstalling the firmware...but before I do that I would like to know if anyone else has experienced this.
