Saudi Arabia DialUp Connection to Internet Via Mobile phone?
2 replies · 2,761 views · Started 14 February 2003
i have enterd the setting of an Internet account .... then i get connected ...i have enterd the Proxy server and Port ... and what ever need's to be done .... but it wont open the Web Pages .. i wonder why ... it just gives me a 1KB loading BAR .... it's all blue and nothing is appearing to me .... just like that .... is it from opera ... or do i have to configure other NETWORK settings .... guys in KSA ... please try it out with ur own and tell me what is ur results about it 😊 ... thank you
Specially Anas .....
Hi
I'm using me P800 on the WAP and its work fine. It is not clear to me that if you try to use Dial-up connection directly without WAP access or not. I can help you with WAP configuration, If you would like to give the details by e-mail it will be fine. 😉
Ra�ad
`Thanx Ra�d ...
i Configured the Dialup Connection ..
what i am trying to do is to get WEB not WAP
u Cant Access a lot's of sites using WAP .. such as Hotmail .. or others ....
but using Direct Dialup to a Regular Internet Account Works ..
but in a Bad Speed ... cz we have bad GSM connection Bandwith ..
go to internet Accounts .... ADD NEW .... then set up any regular internet account Details .. and Select Analog for Connection Type and the Dialing number will BE 360xxxx .... (dont forget to configure the proxy)
and dial using the new Opera Browser .... it worked for me
but only some Sites with fast Access ... because the Mobile connection is very week .. i guess we should wait For GPRS .....
and i am using MMS via nowmms free service on the web
