Several calendar entries/appointments in 'Active Standby'
3 replies · 5,798 views · Started 15 October 2008
I've just got myself a Nokia E71 and so far so good. But there's one thing I would like to have and that's more calendar entries/appointments on the home screen or 'Active Standby'.
I've tried to disable everything else on the home screen except the calendar but it still only shows the current appointment or the next appointment.
Is there any plugin or setting which will show the appointments for a few days ?
Regards,
Jakob Laursen
I'm also looking for a solution for this problem.. It must be possible, in some way, to add more appointments on the home screen / active standby, right??
I posted about this a couple of weeks/months ago.
The number of appts varies, but the most I've seen is 4. You could do some testing, if you can be bothered - create several non-overlapping appts for today and see how many you see with other plugins enabled.
The Active Standby thing isn't very flexbile - there are no 3rd party plugins, and nobody has yet posted about any way to increase the appts display.
Quick tip: This forums isn't very active, so you might find your answers quicker by searching than by posting.
