u can still uncompress and compress from the space doubler program but not from the menu icon. y?? n e 1 else had this problem
SPACE DOUBLEA has stopped unconpressin ma apps
Sounds like your trial period is over???
Could it be that 😃
its registered
Ok 😃 then I cant say. Never had that kind of problem with sDoubler. :-?
No idea. You have tried restarting the phone??
i've got sDoubler and the software would not uncompress when i click on the program, i've got the full version, i've restarted the phone.
it would only unpack when i do it manually thru sDoubler, but if i click on it it should unpack it itself.
can somebody please help if there having the same problem!!!
It's also seem not to be rather stable on packing java application. I tried to pack tipicME and unpack it when i wanna use it, it's somehow crash. Anyone experience it b4?
[quote="rob_harvey16"]its registered[/quote]
Why don't contact Psiloc for support. Maybe its a bug regarding trial period feature. Just get to them and they will get back to you before you know it. 😃
Quick as a lightning! Here it is.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=8024
thanks, but the website still has version 1.31f not 1.40!!!
