Nokie N95 8GB Re-boot problem
1 replies · 4,100 views · Started 16 October 2008
My Nokia N95 GB use to re-boot itself now and then, but since I have update to firmware 30.0.018 it re-boots atleast 10 times a day.
Even if I make a phone call it will just cut off and re-boot.
What can be the problem?
Try the following:-
Back everything up on Nokia PC Suite.
Format the Mass Memory.
Reinstall the firmware.
Check and see if you still have the reboot problem.
If not, then reinstall from Backup but DO NOT restore settings.
A lot of the problems reported on here and other forums are because of restoring from Backup after debranding or firmware updates (or both) as the Settings can cause conflict with the new firmware.
