I have a problem with my E90. I recently bought the phone off one of my buddy last month. The phone was working fine but now all of a sudden it won't work at all. It turns on but it never goes to the home screen. Both screen only display the word "Nokia" and that's about it. I can't use the phone or go even go into my contact. I tried restarting it, connecting to my pc(which doesn't connect anymore), taking the battery out and putting it back in, and all that didn't work. I was wondering if anyone knows anything about this problem that can maybe help me out.
Need help with my E90!
😊Did you check for the batterypower left over ? Or connect at least the power-adaptor while starting up ? Otherwise I wouldn't know and go visit my local Nokia Care Point .
Regards : jApi NL😊
Format the phone...do u have a back up file?
I had this problem. Sometimes if I left it for upto 30 minutes it would boot. Taking battery out for a few minutes sometimes helped but eventually phone "died" and wouldn't get past the Nokia screen. Luckily for me still in warranty and replaced.
I first noticed it (as I don't normally turn phone off) when phone went slower and slower, ie took 30 seconds after pressing a key before anything happened and I thought repowering it might help.
