CoPilot 7 Live
3 replies · 6,088 views · Started 18 October 2008
Installed CoPilot 7 Live on my new i8510 yesterday, seems to work perfectly, even picked up gps signal in my bedroom.Used it to go to work today without a hitch with good clear voice instrutions.Impressed
Don't suppose you have any installation instructions do you? My version is in Spanish and the google translation is awful.
999life wrote:Don't suppose you have any installation instructions do you? My version is in Spanish and the google translation is awful.
**removed**
EDIT
Actually, heres some instructions. Ive removed the "how to crack" section from it.
INSTRUCTIONS (based on UK installation)
1. Copy the following folders to your memory card:
- copilot
- private
- resource
- sys
2. Goto http://www.alk.eu.com/support/choose your country and download the speed camera file if one exists for your country. Put said safetycam.ezp file into \copilot\EU\Save\ on your memory card.
3. UK maps should include POI. No need to download anything else.
4. Put speech folders into \copilot\Speech\. For example for the UK voices the folder is \en-gb\. Put this into \copilot\Speech\ so it looks like \copilot\Speech\en-gb\ on your memory card.
5. Put memory card back in. Startup phone. Install starts. If it doesn't goto App. Manager and start it from the list.
6. Start CoPilot. Enter your product code.
Done.
Locked due to discussing cracked software.
Tired of doing that in this forum section, next ones to break the rules in this fashion will have outright bans.
