how to move sms from phone memory to memory card?
6 replies · 17,279 views · Started 22 October 2008
anyone plz...
I was tryin to move my sms's to memory card.. I used the Fexplorer to move them. Apparently, everything was good, all the sms's were transfered to my memory card.
But, when I try to access any messege...it does'nt open:S. Wut shuld i do?:s
You can't use a file manager to move SMS. The Messaging application won't recognize such a move. In Messaging go to Options -> Settings -> Other and change the "Memory in use" value from phone memory to the memory card.
If that setting does not exist, tell us which phone model you have.
I have the same problem. I eventually managed to change the location of all my SMS to the memory card due to lack of memory space on the internal memory. So far so good but today it had changed to c: again and now I have some SMS on C: and I want to move them to E: (memory card) but how do I do that? I want to have all my SMS on the same place so I can see them in chronological order in my Inbox and Sentbox. I do hope to get a resolution on this problem that is important for me to resolve. Kind regards Stefan
I'm usin nokia 701.I can't change memory settings in my phone.i can't view my sms which saved in my memory card.how can open them?plz rly..........
y2ktharanga wrote:I'm usin nokia 701.I can't change memory settings in my phone.i can't view my sms which saved in my memory card.how can open them?plz rly..........
If my memory serves me right, Nokia removed the feature/support a couple of Symbian OS versions before the Nokia 701 device was released. On other words: You can't.
thanks.....and when i connect my phone via pc suite it only shows phone memory.how can view memory card via pc suite?
