Maximum memory card size for N81?
3 replies · 9,236 views · Started 22 October 2008
Hi and sorry, if this has been answered before, but I'm going to get a N81 (cheaper) or a N81 8GB and I need to know, can I get a 8 gb memory card (or an even bigger card) to the N81? Or is it the same as in the N82?
Thanks already
Mine has 4GB and it works flawless. I haven't tried 8GB, but as far as I know 4 is maximum.
ratza wrote:Mine has 4GB and it works flawless. I haven't tried 8GB, but as far as I know 4 is maximum.
Thank you! :icon14: I had also read some forums (maybe Nokia's own), that the N81 supports all microSDHC-cards, so I'll maybe get a 16 gb one.
take any mirco SD 16gb is the biggest at the mo
anything that takes over two will be SDHC compatible
so if it takes 4 it will take 16
