Hello,
We would like to invite you to help us test our new symbian application called Tagggit.
Tagggit is a web and mobile based social networking application, where you add friends and build communities, and then tag locations with maps/comments/photographs to share with the public or keep private. We currently run on n95 models, and hope to run on more over the coming months.
Using the inbuilt location finder (GPS, Wifi), geotagging your current activity is as easy as pressing a button. From here, your friends, family, and the public around you can see where you�re currently located, or the event/location/highlight you�ve just tagged, depending on your desired privacy level (Its opt in! So you are only found if you want to be found).
We are in beta testing at the moment, and if you like to help us test, then drop us a line (or a pm), and we'll send you out an beta code. You can download Tagggit from here. Any comments or suggestions would be greatly appreciated.
Thanks!
John
Here are a few screens of our application...
