N96 completely dead
8 replies · 6,735 views · Started 23 October 2008
I've found over the past few weeks that sometimes i've taken the phone out of my pocket and it's been turned off (added with the problem that sometimes the sim works its way loose and the phone goes offline - hence I miss countless calls).
Today i've taken the phone out of my pocket and it was off, now it won't turn back on, won't charge...it's completely dead.
The end to an overall very bad 2 week long experience for me, I won't be replacing it with another N96 that's for sure.
Back to the E90 for me. :icon13:
where did you get it from? .. or maybe you could just visit the local Nokia Service Center and check it with another battery?
Good Luck!😊
Has been happening to mine about once per day since I had the phone, are you on T-Mobile by any chance?
Mine either crashes while I am using it or I get it out of my pocket and it is seemingly dead (black screen). When it crashes I can't turn the phone off, I have to take the battery out and put it back in (most annoying). Really hope it stops soon this phone would be amazing apart from these problems I am having.
The phone is an unbranded model but i'm using Orange, certainly nothing to do with the service provider.
The build quality of the phone feels very flimsy anyway, but then I guess it is a mass market phone...just with the price tag it's currently selling for you'd expect it to feel a bit more robust.
J2theIZZO wrote:The phone is an unbranded model but i'm using Orange, certainly nothing to do with the service provider.
Pretty sure the Orange one is branded...
zuk1 wrote:Pretty sure the Orange one is branded...
The Orange one may well be branded, but he didn't say he has an Orange handset, only that he is using Orange 😉
Luckily after the update my phone is running very smoothly with no crashing thus far.
