To Format or not 2 .. that is the Q ?
9 replies · 2,527 views · Started 19 March 2002
Hi all,
Formating on my old 9110 was easy click on the 3 magical keys and vulla its formated.. since i bought my 9210 i've managed to formated it twice without any problem .. now when ever i try to format it, it gives me nothing ... just returns back to the main screen like a normal reboot does !!@ , i've tred everything from removinng the MMC, formating thru the explorer software .. any ideas ?? my frameware is the latest 4.13.
If you need to format MMC I recommend to close the machine, remove MMC. Reboot it. Then insert MMC, Start FileMan and format the card.
If you need to format device card
First, remove(uninstall) any localization software, etc (that can be run at startup and prevent formating). Reboot machine. And when the "hands" are appear strike Ctrl-Shift-F.
Please be VERY patient when formating.
Regards,
Zeus
I had the same problem!
What did I do?
I change the localezation back to normal and i unstalled 2 programs... the localezation and the OPL... and voila worked like a charm!!! (sorry about my english)
Coolmatter
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Did you see format progress bar after you've pressed Format button for a little and then "Hands" immediately?
You should UNINSTALL (not turn off only) all programs that can "patch" your system before.
Umm... Zeus... I was trying to help! User posted image
I know that and I was trying to explain how to make it work (format)!!!!
I don't have any problem! User posted image
Thanks guys,
I did uninstall almost everything but the only software that i couldn't uninstall was the Arabic font from PSI it always says file in use even if i disable it i still can't unistall it !!!
any hope ?
Umm...
Install the SwissA.sis again and then the Arabic PSI...
Enable the Arabic PSI, reboot, disable it again and then uninstall it...
it should work that way...
On 2002-03-21 1909, Q-Fever wrote
Thanks guys,
any hope ?
Well, you can first use FileManager to rename the folder of Fonts (C/system/fonts or D/system/fonts) and then use TaskManager to restart the machine to do the Format procedure. After formatting machine, you can rename back your Fonts folder lor..
