Nokia do seem to be getting better at communications with the outside world, as evidenced by the very switched on and honest status update just posted by the 'Nokia Email' service team. If you use this service then take a look.
That's what I get when I click on the link:
Error establishing a database connectionThis either means that the username and password information in your wp-config.php file is incorrect or we can't contact the database server at localhost. This could mean your host's database server is down.
* Are you sure you have the correct username and password?
* Are you sure that you have typed the correct hostname?
* Are you sure that the database server is running?
If you're unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
Seems they are pretty honest indeed. Kaput!
