n95 8gb built in audio player crash
3 replies · 4,885 views · Started 24 October 2008
plz , some help :
my nokia n95 8gb crashes and reboot when it's playing with it's own player an audio file (wma , aac , wav) but not when playing mp3 files ,i tried all this formats with many bitrates .
There's no problem when using an other player to play the same previous formats (ogg player , core player) !!
what's the prob ?
how can i solve it ?
thx
First Make sure... the bitrate of the songs dont go over 320Kbps,
secondly what version of the os you got?
You should upgrade to the latest firmware which is v30.0.018.
if you dont know how to check press *#0000# to check your revision...
If you have already upgraded to the latest firmware or u already got it.. try a hard reset.... *#7370# - then enter the phone lock code which is 12345
Make sure you place your songs neatly in the 8gb flash section in the "My Music" folder. Re-organise it instead of dumping a chunk of .mp3 or .wma in a directory. it can help make the phone perform better...
after that.... open up the music player and refresh your playlists. it will take roughtly 2 mins under.
1/the bitrate of the songs dont go over 320Kbps (wma 64kbps , mp3 128kbps , aac 112 kbps , all 48000hz)
2/os version 20.0.016 , i'll update it just after saving the phone.
All the songs are in the 8gb flash section in sub-folders of my music , each album in a separate folder.
i'll reply after the update ,i think it will make few hours
update to v30 succeed , wma problem seems to be solved , i have just to reinstall some app 😊
but still 1 prob i can't reinstall "trk" to hack the phone , i'll post a thread about that , thaaaaaaaannnnnnx mr.Freakster
