is it possible to hide our own caller ID, so that our own number won't be shown if we call other mobile phone?
hide Caller ID
That depends on your service provider
yes ,punch in the number, then before punching ok to send @ the right nent to C , punch that key then simply select "hide my number"
mrgadget
i found your instructions a bit confusing... should i add an @ after the number as in:
5551234@
then hit OK?
please elaborate.... thanks
1. Punch in the numner you want to call.
2. Press the button in the upper right corner on the keypad (the one which looks like a small box with something written in it).
3. Select "hide my number" in the menu which pop ups.
4. You call is now made.
I think this feature is network dependent. You might want to ask your telecom provider if they have this kind of service available, other wise even if you try to hide it, it will still show up
OK. i just tried that & it doesn't work here in Kuwait...
then it depends on if the service provider would allow it...
oh well
Try dialing #31# before the number;
eg. #31#5551234 <dial>
it dosen't work here in singapore also
#31# and the number i think works with tmobile us only ,tried it on my home phone ,doesn't work.
