Hi there,
i installed the PC-Suite for the P800 and wanted to sync my contacts with Outlook XP. At first nothing happens. Then I realized that Outlook opened a window in which it requested a confirmation to allow the software the access to its data for 1-10 minutes.
Is there a possibility to allow the access everytime?
Thanks a lot
Michael
according to microsoft this is only possible , when you use a exchange server.
maybe , some code cracking could do the low , but this enables a unsecurety for virussen witch use this same feature (like i love you virus)
so , i'm not sure yet if it is wise to disable it completely.
grtx , arnold
Search for a program (freeware) called "ClickYes". It doest just that - virtually clicks yes when programs access MS Outlook. I needed it for my R380 world, and works just as well with my P800 now.
-Dan
That's what I call a Work-Around 😉
Thanks a lot
Michael
