IR-Printing from 9210 via PC to normal printer works!!
0 replies · 1,812 views · Started 20 March 2002
Download this shareware http//kevin.millican.net/Home/PassThru.htm . That part of the shareware you need is freeware.
Have installed the virtual COM-port for IR under Windows.
Start PassThru, select the correct virtual COM-port, press Icon "Start PrintThru".
Select the correct printer driver on your 9210. And print, print, print, print .......
