9210 with Lotus Notes R6
0 replies · 1,843 views · Started 15 February 2003
I have just changed to Lotus Notes R6. I am able to synchronise both calendar and e-mails of my 9210 using PC Suite but anable to synchronise contacts. I get an error with names.NSF-file. I already tried to get an NTF-file (pernames.ntf) from my colleague because his syncronisation has no problems but mine still gives the same problem, so there has to be something wrong with other associated files which reflect the NSF-database (names.nsf). Interestingly enough, I realised that I am able to synchronise the address book/contacts in our corporate server! Having realised that, I changed the design of my personal address book (local) to the design of the address book in the server and after that synchronisation can be done! However, the access rights, format, etc. are copied and therefore I cannot leave the local address book to that "design" because then I do not have access rights to modify it. Your helps would be highly appreciated. It is a big problem for me to change the names.NSF database design whenever I want to synchronise and then change it back to local personal address book (pernames.ntf) design when I want to edit/use it in Notes.
