Hi
I'd like to view the n95 screen on the computer, is that possible?
Thanks in advance
Regards
Hi
Thanks in advance
Regards
just buy or use the trial from mobiola webcam.
with that programm you can view the cam, front cam and the screen.
connectivity via wlan, bluetooth or usb is available.
have fun
shouldn't be a problem .. hook it up to the TV-out cable supplied ..
Good Luck!😊
Using TV out cable, in TV out mode, you can just watch the exact duplicate of your Nokia N95 screen.
erehman wrote:Using TV out cable, in TV out mode, you can just watch the exact duplicate of your Nokia N95 screen.
But i want to connect the n95 to my laptop. It doesn't have the necessary TV-in slots.
I know that for ngage there was a program that we could connect to a cmoputer and it would open a window in the computer that had the exact image that was on the phone.
Either way I'll give it a try with mobiola webcam
