Hi.
Does anyone know a decent editor to create professional photos? I.e. Sharpen the object in the photo and blur the background?
I have attached a jpg as an example. The hand is sharp whilst the eggs in the background are blurred...
Thanks.
Hi.
Thanks.
try fotoflexer.com its an online one but its free,might not do what you want but worth a look
Hi.
Thanks for that. Tried it but it doesnt allow you to select the image, i.e. outline and then blur the background...
Cheers though.
