Broken LCD screen, please help me!
19 replies · 5,848 views · Started 16 February 2003
Hello to everybody,
I've got a mayor problem, the small cable [I believe it is called a flat-cable] from the mainboard to the LCD screen is broken. [I did it myself, I know, stupid move]
Nokia won't repair it because I did it myself, and they didn't know who could repair it.
So I have 2 options: Trashcan or repair it myself. I prefer the second.
Does anyone know where I can buy that cable? Please help me out!
Cant you repair the cable? instead of searching for a new one?
If you just broke the wires you should be able to reconnect them with a soldering-bolt. It that's hopeless ... use the connectors and a ide cable or something to recreate it ...
Well, I don't know when it's completely hopeless, but of the 10 wires there are 6 broken. I can try to solder them together but I haven't used a soldering bolt in 7 years... It's not the situation that's hopeless, It's the owner... 😮ops:
But I don't know what a new flatcable costs, so my first solution was to go and look for a new one... If I can't affort it I can always try to fix it myself.
[quote="unsound"]Hello to everybody,
[/quote]
I am shure that they will repair it for money....Not Warranty..
Go check it out... 😉
I tried it twice, but they refused.
I also asked if I could buy the flatcable but they said only their own repair-shop can get flatcables...
So I guess my only option is to go and buy a slodering bolt, but I'll probably end up frying the hole cable... 😞
Just to show you what the problem looks like:
I`ll ask at Nokia Center here tomorrow.
Just ask them and I`ll drop you a line with the price and so on..
[quote="n1ghtFLY"]just wanderin what did u do to the flat cable so i will not do the mistakes like u did 😃 😃[/quote]
on the main chip there are some iron clips, probably to hold it in place... while is trying to remove the flatcable it got between the clip and the chip and the clip went right throuh.
I've included a picture of the situation as it was at the time...
WELL THIS IS JUST GREAT, FINE AND DANDY!!!!
I called EMTS like you guys advised, and what do I get? some smart-ass telling me they don't have spare parts! :evil:
And when I explain the problem they advice me to go and look for a used phone on the internet because they can't fix this!
What kind of a repair shop is this? or did I just end up with the only retarded employee? :agrue:
[quote="Anonymous"]I`ll ask at Nokia Center here tomorrow.
Just ask them and I`ll drop you a line with the price and so on..[/quote]
I got them over the phone today.
The cable band costs 50 Eur and the instalation is 10 Eur.
They got it on stock.
If you need them...well don`t know if they speak english..0040 21 2242596.
I have a friend there, that helped me a lot 😉
Tell me if you want me to purchase it for you
YES YES YES YES! BUY IT!
if you're a woman I'll kiss you, If you're a guy I'll send my girlfriend to kiss you!
Oops, almost forgot, is it a complete cable? there should be one or two chips on it...
Just pay �150 to Nokia for a new cover and they'll replace that little wire, its better than spending �600! 😮
hello There,
I am flying back and forth from Romania to the Netherlands every two weeks. Would be happy if I could help you to transport the phone or the parts. Next flight to Holland will be somewhere the 6th of march. I stay a few days and fly back to romania. If that can help you.
Huib van den Oever
[email protected]
