My Palm can't compare to my new E90. Nokia is far superior. One big question -
I have over 1,000 contacts in my Palm. How do I get them into my E90 without rekeying - that would be a royal pain!
Thanks for the help!
I've never used Palm, can it out put them as vCard format? if it can then add them to your address book and use it to sync across to the e90.
Or how about using something like shozu? I use it to keep a backup of my contacts, you might be able to upload them from palm, switch your phone to teh e90 and then sync it back down?
Yes, the easiest way is to syn your palm contacts to outlook or to an online servie like Plaxo. Then sync with the E90.
Cheers,
Thanks guys! I'll look into all those ways. Would have never learned of the online services without you.
Even for me, a green novice, my E90 beats my Palm all the way around.
