auto key lock
9 replies · 8,275 views · Started 16 February 2003
can ne1 gimme the auto key lock software here plz if it is free and dont ask me to search since the search on this site gives me no results of wht i want. if its free plz mail it to my e mail. i do have tht indian made key lock but it never keylocks. think its made my karthik. i dont want tht 1.
thk u
download SeleQ, open it on your phone and then just leave it running, go to your main screen and close your slide, it should lock on its own
Jes,
you have to run the keylock program and let it REMAIN RUNNING for it to work. Thats what ive notice with keylock. It wont lock "automatically".
So when u reset or turn off your fone, u have to run the app again and so on... if u like here... but tell u, it will be the same as yours...
Jes,
One more.... Entended Profile Pro. That will works too.
[quote="RoosteR"]download SeleQ, open it on your phone and then just leave it running, go to your main screen and close your slide, it should lock on its own[/quote]
[quote="Edgedale"]One more.... Entended Profile Pro. That will works too.
[quote="RoosteR"]download SeleQ, open it on your phone and then just leave it running, go to your main screen and close your slide, it should lock on its own[/quote][/quote]
The thing about EProfile is, you don't have to run the app after restart, it's somehow part of your startup apps. But for you to modify settings, you have to run the app. 😃
😃 YES!
[quote="kobe24"][quote="Edgedale"]One more.... Entended Profile Pro. That will works too.
The thing about EProfile is, you don't have to run the app after restart, it's somehow part of your startup apps. But for you to modify settings, you have to run the app. 😃[/quote]
thx ppl a lot. i know how it works now. i would like it if u dint have to play it in the background but hey wht the heck. thx for the file pidz111
no probs jess 😉 yea, i like it better if you dont have to start it manualy and put it in the background. It is just a small app unlike those of seleq or eprofiles...
