No SMS alert
4 replies · 2,148 views · Started 16 February 2003
Hi.
found something annoying out:
When your phone was turned off and you received a few SMS during that time, the SMS arrive silently when you reactivate the phone.
There is no audio or anything visible alerting you. Like in a "regular" phone. You have to go yourself to the SMS folders to check.
Quite bad, especially if you have SMS alerts from your servers.
That can't be a feature? Since I just upgraded to R1D, maybe a new bug.
Danny
...yep. All ok.
It more looks like a timing issue when an SMS is coming in and the system is not up correctly.
All my other SMS later arrive with notifications.
Danny
i have a problem too. i selected a midi as my alert for SMS. It rings when a message is received but it won't stop even after reading and deleting the message. It will only stop after the whole midi is played. Are you guys experiencing the same?
