Registry cleaner
5 replies · 36,576 views · Started 05 November 2008
Hi can anyone help me out with cleaning unwanted registry on my N73ME???
I have hacked my phone so i can open PRIVATE n SYS folders of my phone memory which contains registries...but i don't know which one to delete as their names are in some codes....
dralban wrote:Hi can anyone help me out with cleaning unwanted registry on my N73ME???
The entries in these folders (primarily Private - don't touch sys!) that are remaining will be related to applications installed and then removed. Doubt you'll gain much from clearing them out, other than a little space.
clonmult wrote:The entries in these folders (primarily Private - don't touch sys!) that are remaining will be related to applications installed and then removed. Doubt you'll gain much from clearing them out, other than a little space.
So can i delete registry folders from PRIVATE without any crash to phone or mc??? Wat are there in SYS folder???
Before you proceed kindly take a backup of your phone data and PC registry data on your PC and then check if it can help you in anyways :icon14:
If you want to delete files related to Nokia PC Suite's registry from your pc you can try using Nokia PC Suite cleaner 7.0 you can do some googling for the same else for whole PC unwanted registry cleaner you can check with CC Cleaner.....
