webcam speed on remote 60
4 replies · 1,719 views · Started 16 February 2003
Hello people,
I was wondering what kind of speeds you get when using the remote 60 app and the camera app on the phone.. What's your refresh rate? same as when viewing without remote 60 active? Mine is quite a lot slower. I use bluetooth/serialport.
thanx
The refresh rate is of course definitely slower than if you use the phone without RS60. It is too slow to play most games for example, but it is fast enough to use all my apps without problem. I use Bluetooth and TCP/IP.
[quote="wannyondeathrow"]What is connecting via TCP/IP[/quote]
To connect via TCP/IP, you have to do the following:
With the PC software: Go to "File - Setup - TCP/IP" and activate TCP/IP. Press OK. An IP Adress will now be shown on the main screen (see attached picture).
On your phone: "Options - Network - Other..." Now enter the IP adress and the port number that the PC software shows, in my case: "192.168.120.254:4567". That's all, now you are connected.
The advantage of this method over connecting via COM port: I can use my two favourite programs at the same time, the Epocware Filemanager (via COM port) and Remote S60 (via TCP/IP)! The disadvantage is that it might be slightly slower than connecting via COM port.
hi
you can get better FPS of refresh for Remote Control changing the options for quality... COLORS = 256 .. or change to JPG Quality LOW or VERY LOW.. to more speed.. the CLOCK Mz... put on 2 or 1
damn nice app...!!! 😃
cya!
