Garmin XT now supported
6 replies · 4,839 views · Started 06 November 2008
Changes made from version 5.00.00 to 5.00.10:
Provide support for Samsung INNOV8 (i8510).
Change default vehicle icon to blue car.
Correct an application shutdown when frequently recalculating a route.
Correct the displayed speed limit value for some specific roads.
Correct the blank green screen displayed when switching to the map page.
Improve the layout of the Local Search capability.
Improve the layout of the map page for the Nokia E90 screen size.
http://www8.garmin.com/support/download_details.jsp?id=3939
Since Garmin now works on the i8510 has anyone an opinion on with is better
Copilot/Garmin/Route66?
vudluxi wrote:Since Garmin now works on the i8510 has anyone an opinion on with is better
Copilot is horribly clunky and buggy on S60
Route66 seems good except for an annoying habit of stoping following your current location while routing (necessitating a couple of menu presses)
Haven't tried Garmin
I use Sygic Drive (A version of Sygic McGuider) which i find is a good navigation program.
My Route66 works perfectly, did u install the latest update? Sygic is good too, a little slower and sometimes calculates stupid routes, another difference is that u have to turn on the Gps data first, with Route66 it�s automatic.
I use Route 66 on my I8510 for work every day and find it to be accurate and fairly easy to use. However i would still switch to Garmin XT as I used that on my N95 and liked the wider range of options available and the 'easier on the eye' menu system. Nice to see that the XT app is now compatible with the I8510, so I hope to be able to get that up and running again now. :icon14:
