What case/pouch for the Innov8?
6 replies · 4,487 views · Started 06 November 2008
Such a pricey phone should have a pouch. What the market offer? Anyone has tried some good ones?
I am using the HTC case for the Touch Pro. It is an exact fit for the Innov8 and also has an opening that allows the headphone to be attached while the phone is in the case.
I've just bought an Ebay special from our far east friends! Its a custom fit rubberised hard case which clips onto each half of the phone. Not put it on yet as I handed my phone back to CPW today under warranty, but I think it will do the job. Has a hard plastic screen cover too.
is that case any good ^^^^^^^, u know fit wise. does it still let the phone slide properly also anyone know of a good case to stop the dust problem. or if there is any way of covering the hole.
I know you're looking for a pouch, but I have the hard case that glanma mentioned. It's pretty decent for getting 2 for under $10. The case had some scuffs on them but you can see the screen just fine through the plastic. I actually prefer the feel of the phone with this case. It gives it a little more bulk so I don't always feel like I'm going to drop it.
And luckily, I so far haven't dropped the phone so I don't know about how well the case protects it, but the phone does still slide properly. Just buy it and try it out. It's only like $9 on ebay. I can't post HTML links yet but just search "Samsung Innov8 case."
The longer the Innov8 is out, the more accessories will become available. There's also now a silicone one on ebay but it doesn't appear to have a screen protector.
I prefer the look of the clear plastic to the silicone but if someone gets the silicone make sure to post your impressions.
