has anyone installed the newer version of the midp thing?
can it be installed over the older version or remove then install? will removing the old version first cause the uninstalling of the installed midlets?
mouthfull of installs there
I installed it over the original and it works fine. Compatibility seems to be much improved, but I still can't get Quicksilver IM client to work, and some MIDP applications won't even install.
