Video player problem " realplaer"
2 replies · 4,610 views · Started 08 November 2008
when i play any video "recorded by camera or transfered from pc" the screen is like 90% darker than the normal colors..? whats the problem ...
i tried realplayer settings and i found the contrast set to 0% ....is this the problem ? tried to set it to any other % but it wont save as soon as i press back then get back again the contrast setting reset to 0%...this problem only with the contrast the other options get saved when i change them ?
any idea how to solve this problem its really annoying...and any idea if i can update my realplayer or sumthing like that
by the way...when i play the videos on CorePlayer they are fine normal colors ....
thnx
There's a setting for screen brightness when playing videos. I can't remember quite where it is, but would have expected it to be in Real Player
i had the same problem but only with videos that i recorded, pleaseeeee someone tell me what to do:con?, thanks alot.
dose anybody know the solve for my problem?!!!!
