N85 and Video problem
5 replies · 3,437 views · Started 08 November 2008
I have the n85 for the last 2 weeks and I am very happy with it. I only had some minor video problems but since today no video is playing any more. I just see a black screen. I have tried both videos taken with the phone and videos I have downloaded. I have tried copying the video to the internal memory but still I get nothing. Any ideas? Thank you
yeah, turn the phone off and back on again.
I have experienced this a few times now and its REALLY annoying!
in the bigining i had only a few problems with the videos and if i restarted the phone it worked but now I can see no videos at all even after restarting. The same problem even if the video is in the iternal memory or the card. Any ideas?
I have also installed the java youtube app. While in the begining it used to work now it just shows a black screen now... I have restarted the phone many times... Any help?
Dont know... I had the same problem a few times with the black screen but all ok now. Have you installed anything that could be using your video player that you can remove to try again?
I can oly think or youtube mobile and mobitubia.
Do you think this is sw bug which will be fixed when an update comes out?
Is there another media player that I can install to view videos?
