how the hell do i get my operator logo back to the original one!! ive searched to no pravail, when i did the op logo thing my wildskinz stopped working so i tink thats that problem, if anybody knows if thats whats wrong plz tell me cos its peeing me off
Op Logo!!!
i got the op logo off, but wildskinz still isnt working
HI!...
i think that the problem is not the OP LOGO THING....
the problem is WILD SKINZ ...
that APP is not too compatible with many apps...
so.. in some cases you have to turn off... or simply remove that
but... like you can see i have SKINS and op logo working at the same time fine... so that is not the problem...
cya!
That screenshot just screams "BOY'S PHONE" at the top of it's voice!
LOL!
ive taken EVERYTHING off my phone, reset factory settings and tried again with wildskinz but it still wont work, it says its doen it and is going to restart, but still nothing, but i had it working before dunno whats wrong 😞
are there any other softs except seleq which has "set as op logo" option??
only things i have on my phone are SeleQ, Screensavers, RemoteS60, Hantro, TipicME and WildSkinz, now ive had it working before and it just seemed to stop when i either put space doubler on or when i changed the op logo, ive taken space doubler off and it still wont work, ive installed and unistalled sooo many times, when i go to change the skin it does it all ok and says it will be complete when i restart my phone, so i do and it never changes anything, its annoying to say the least, especially when i know its worked before... if anybody could help i would be really gratefull
and that helps me how?
