Just downloaded the Latest version of PC Suite 7.0.9.2
After installing XP says I have a fatal error with the driver.
The PC does not recognise the 6120c
Have tried using Device Manager on the PC to reinstall/update the driver but still get a Fatal Error.
Any ideas?
:con?
Do have backup of your phone data & PC registries then
Uninstall Nokia PC Suite, Nokia Connectivity cable driver, PC Connectivity solution, Nokia flashing cable driver(if any on your PC), Run PC Suite cleaner. Install latest Nokia PC Suite from nokia.com/pcsuite, reboot your pc. Once pc started, connect your phone with USB in different ports of your PC and check 😊
BTW the latest pc suite version is 7.1.18.0
Have a great day 😊
