Hey Folks,
I have the P800 for the past 2 weeks and it was FINE.
Ever since yesterday, my communi-can starts to behaving strangely.
For no reason, the preview screen will stop functioning - i will either get a SE logo or a freeze frame. I can still take pictures ( i just cant see wat i am taking ). Only way out is to shut down and start up again. This happens quite frequently.
I am using the latest firmware : R1D.
IS IT TIME TO CLAIM WARRANTY ? Pls advise.
Thanks.
Battery level is above 50% all the time.
How much power is required to avoid this ?
It's not low batt. It's low memory and RAM. Either free up some space, or keep closing applications as you are done with them.
[quote="brick"]It's not low batt. It's low memory and RAM. Either free up some space, or keep closing applications as you are done with them.[/quote]
Ok, this might sound a bit stupid 😮ops: 😮ops: , but how do you close the apps??? I mean, for example, you can't close Calender or Messages, can you?
Yeah - How do you close an application anyway ?
Just use File Manager, select File and then Task list.
Thats the thing - i dont think i have a file manager ....
keep hearing abt it - but how do i access my filemanager ? From Applications ?
I'm using SE P800 btw.
I'm talking about an app for the P800 called File Manager. Install this app in your P800, it's a must-have tool to access and control all the files in your phone. Funnily enough I couldn't find it in the P800 download section here at AAS...(what's up with that?)
Well, then, just look for it in the UIQ download section at www.my-symbian.com
Cheers
Here: http://my-symbian.com/uiq/applications/applications.php?fldAuto=14&faq=2
