Hi everyone! Could you help me sort out a problem? When I open file manager and browse through the mmc files I see that I don't have the file d:system. This is strange because I can see and modify it through pc suite! How can I start seeing it again even in file manager?
Thanks...The Godfather. :P
Strange thing
Do I understand you correctly? You can not see the system folder when using FileManager on the 9210?
Go to Menu-Tools-Settings and change the "Show system directory" to yes.
Yes,but it is the system directory of d! There is no option to hide it and un hide it as there is for the c system directory!!! I hope I was clear... :-?
An indication that your filesystem on the mmc is messed up ...
Can I re-create it? How?
format 😃
oops, sorry misread something ...
if it's only the system folder that doesn't show ...
it could be that you haven't selected "show system folders"
but it could also be that your system folder is corrupted .. in this case format ...
(I had this with c:\system\data, could only view using pc suite not filemanager)
I did format but it seems that it doesn't re-create! Should I do it manually?
:s you've formatted the mmc? and you still can't view it? you've also checked that the "show system folder" option is activated?
I'm guessing something is wrong with your 9210 (could be just a software issue) since you weren't able to format it from your 9210 and now this happens ...
I think it's an mmc problem. This happened 1 year ago when I had the 9210 (now I have 9210i). Accidently one night I erased d:system folder and I was never able to get it again,but I could see it and fiddle around with it through pc suite!! Strange...
Dazler!!!!!!!!!!!!!!!!!!...the format worked..I can see it now!!!!!!!!!!!!!!!!!!!!!!!!!!Thank-you so much!!!!!!!!!!!!!!!! 😉 :P 😃 😃
LOL
the most powerful thing to fix a problem is to format the phone and every gonna be alright 😃 😃 😃
Yep!
[quote="n1ghtFLY"]the most powerful thing to fix a problem is to format and everything gonna be alright 😃 😃 😃[/quote]
Maybe I should try this on my girlfriend 8)
Why not...? 😉
Depends, she has a big harddrive, so to speak. can't remove her battery as well, that's called murder here in the netherlands... 😮
Try a re-boot from time to time...might help! 😃 8) 😉
