Hi! My Nokia E90 is having problems. The screen had spontaneously turned completely green, and after pressing a random button it turned red. When I pressed on another button the screen went yellow. This has only happened two times in the last two weeks. The phone is much older. I have to take out the battery in order to make it fine again. Do anyone have suggestions to what the problem might be (I have not yet updated it to the very newest firmware)?
Screen on e90 goes completely green, then, red, then yellow
Is it the outer or inner screen? If so, it has probably to do something with the hinges.
LD
I forgot to say that both screens are like that.
upgrade the firmware first.
just figured out what the problem was: the torch application had somehow turned on by itself. Then, by pressing the d-pad I could switch between colours! Pretty neat actually, now that I know what it was!
