Problem reading 'Lock Code' with Nemesis Service Suite
1 replies · 12,675 views · Started 11 November 2008
I forgot my lock-code like a lot of people. :frown:
Offcourse i've tried the original code which is 12345.
Also tried http://www.nokialockcode.com/.
And tried http://www.symbian-toys.com/unlockme.aspx
Also contacted the 'nokia service centre' but the only solution they offered was to reset the entire phone.
So none of that seems to work for me.
So i did a lot of research on how to reset it without resetting the entire phone.
The only solution i have found is the following: http://gopu0000.googlepages.com/nokiapsb
And it works all the way to where it makes the 'pm' backup-file.
Only when i open the file en go to the '[308] section', i don't have a '5th line', it only shows 4 lines..
Does anybody know why i'm not getting a 5th line??
I fixed it!
The second method works!!
handphone-solution.blogspot.com/2008/06/how-to-recover-lost-security-code.html
