Helloouu...
Can somebody help me with midlets..
I have installed <B>MIDP 1.0</B>, and i want those coool http//www.dseffects.com/ stuff to run on my 9210.. When i install eg. snow, it just says "starting...." and nothing happens. Have i done something wrong?
Hi JeP,
Seeing that nobody techy has replied I thought I would let you know that I hadthe same problem it was lack of memory I found it seem to work when I had about 2.5mb
I should add that most of the Midlets I have do not work or run very very slow, I have tried some of these before and they did not work, they only showed the date.
Have you tried SDL the fire and ripple effects are very nice.
http//koti.mbnet.fi/~haviital/
Hello..
Thanks for reply.
I have 3.2mb free in device and i reinstall midp something about thousand times and i got it work
How about running midlets in fullscreen mode?
btw, your another reply, i try those asap.
looks gooood!<font size=-1>[ This Message was edited by JeP on 2001-10-08 1641 ]</font>
maybe next version of MIDP for 9210 will be more speed ...
I am the author of the DS Midlets and I will insert other midlets asap.
www.dseffects.com
