i8510 NO GPS LOCK,Garmin XT 5.0 NOT WORKING!!??
4 replies · 8,850 views · Started 12 November 2008
After 10min under clear sky,Samsung Mobile Navigator (Route 66) cannot lock gps data...When go in to View->Sat data...say no data!
Is this normal? And is there something to do if I dont have Serbia map installed!
Also I installed Garmin 5.0 latest...and when I enter Garmin,Garmin just close by the time it needed to go to Main Menu! What should I do and what navigation to install to i8510 that will work?!?
It doesnt work becuase you have to buy it. The update is just that - update only. You have to buy the memory card with your map region on.
bartmanekul wrote:It doesnt work becuase you have to buy it. The update is just that - update only. You have to buy the memory card with your map region on.
Work great!!! I just had to put i8510 in car holder! And in 10sec it locked GPS signal! I have bought it!!!
hey guys i got the same problem the gps doesnt lock even when i go through gps data thing on the phone why is that, i thought this phone had an internal gps reciever????
