Anybody knows of a way to set permissions for opera mini so that it will connect, store etc. automatically, without having to nag me everytime with questions whether I allow it to do this or that? I think I know how to do it, but I can't seem to locate the opera mini folder in my N95, so as to change it. Any help would be appreciated.
Set permissions for opera mini so that it doesn't ask the same questions all the time
there are two versions of Opera Mini, one allows you to set permissions upon instalation, the other one doesn't. You have to make sure you have the right one.
neriano wrote:Hi,
Into Application Manager, highlight Opera Mini then select Options then Settings.
It might also be:
Into Application Manager, highlight Opera Mini then select Options then "Open" - this opens the settings not the application.
Burcrim wrote:It might also be:Into Application Manager, highlight Opera Mini then select Options then "Open" - this opens the settings not the application.
Well, you get the idea 😉
I've only got an N85 on me at the moment, so it was my best guess......
