Can you change gallery programme or choose specific folders?
0 replies · 4,178 views · Started 15 November 2008
Sorry for the rather long title. The problem I've been having is trying to view any pictures with the gallery. The trouble seems to be that because it tries to show all possibe images stored on the phone (including snippets from installed programmes such as iplayer or Garmin) it crashes the gallery or at least takes a good 5 mintes to open. When it finally does open there are some 2000 images, I have only taken about 20 with the camera.
My question is; Is it possible to change the default programme used when selecting gallery on the slide button?(a major issue I've found is that if it's set to gallery when I want to take a picture I need to wait the 5 minutes before it loads before I can switch it to camera...not ideal...)
Or is there any possible way to limit the gallery only to open the images within certain folders?
Can anyone suggest any decent photo viewing/editing software that will work on the i8510?
Thanks in advance.😊
P.S The dust in my screen seems to be getting worse....
