Single sis files
8 replies · 2,042 views · Started 18 February 2003
Hi...do you know where can I find all the single sis files that are part of the "big" all_nokia_9210i_data_it.sis...?
There are just some of them on the nokia site. The others are missing!!!! I don't know why they didn't put them all there... :-?
Thanx... :P
get the files from your back up ...
just select the few files you need
I only installed:
display
profile
imaging
clock
by restoring only those files from backup (could be one or 2 more, can't remember exactly)
I don't have a back-up. I keep everything in my mmc! No site where I can download them? Is it banned to shre them in this site? 😮ops:
Thanks...
Exell,imaging,control pannel,www,and the power point app. Excuse my translation but I don't know the names in english! Btw,when I format and ready to re-install everything,I don't have the option to select where to save the softwares! It makes me install them only in the c rom! Not only when I install all nokia etc.sis but even when I try to install the sales package software one by one!!Weird!!!
all those apps are available from nokia.com in single files
your 9210 seems to be unable to proper detect your mmc ... see if it is inserted properly and that the pins make contact ... you could try pushing it down by inserting a piece of paper between the iron cover and the mmc.
