Does anyone know if it is possible to disable the screensaver and keep the backlight on when this phone is charging? Thanks in advance.
E51-Disable screensaver when charging
Anyone?
Don't tell me I've found a feature that WM6 has and isn't in Symbian!
Install "Smartlight" and there you go.
Thanks ziffos, unfortunately that doesn't look like it does quite what I want. I have a desktop cradle and would like the backlight to stay on when it's plugged in and on the home screen, not when an application is running. Any other suggestions?
id be really intrested to know if there is an application too and i dont mean smarlight either i am after exactly the same as KLockwork is:icon14:
I've eventually found something that will do what I want. Small app called 'Lights On', cost $7 I think. Slightly annoying that you have to pay for such simple functionality but I have to say, it's worth it.
Here's the link: http://www.softwaremarket.nokia.com/?action=productDetails&pID=2378&pmsid=305&lang=en
