Does anyone know which settings to activate for this?
When I receive a call, I open the slider and it answers, yet when I close the slider it doesn't end the call. This caused problems today, as I phoned my wife, it went to answerphone and I hung up (or thought I had), she then tried to call me back, but I was still connected.
I'm sure it used to do this, but can't find it in any of the options.
try settings -general- slide handling this should solve your problem adjust settings
radical24 wrote:try settings -general- slide handling this should solve your problem adjust settings
I don't seem to have that on my N96, all I have are these
Personalisation
Date & Time
Enhancements
Navi Wheel
Security
Factory Settings
Positioning
I've been through all those menus and can't find anything to do with the slider
hmmm so sorry, did not realize that n96 has different set up from n85, you would think it would be the same or fairly close to that given that they are both running FP2 ....hope you can sort it out...and sorry could not be of help....best in getting it resolved
If it's anything like the N95 there is no option to hang up when you close the slide.
The N85 has the option, and being FP2 you'd think the N96 would have it too.
Maybe it'll be in a firmware upgrade at some point?
try to google slidehelper a little program i use on my n95-3 i am not sure that it is compatible with fp2 tho, hey you have nothing to lose and the app does exactly what you want, sorry forgot about it earlier
radical24 wrote:try to google slidehelper a little program i use on my n95-3 i am not sure that it is compatible with fp2 tho, hey you have nothing to lose and the app does exactly what you want, sorry forgot about it earlier
Cheers for that, downloaded and works perfecly :icon14:
bubs999 wrote:Cheers for that, downloaded and works perfecly :icon14:
i am glad it solved your issue 😉
