hey everyone ....I just want to know when i Connect with dialup and when its connected does the G appear instead of the signal sign or does a D or something come :P
and when I try to connect webviewer with dial up i get a calling sign on the rop right of the screen and then I get disconnected??
can someone tell me how to connect dialup with webviewer?
and also I cant go to any websites with doris browser?? whats this
it used to work fine but now it dosent could someone tell me whys that...
and I want to know whats the Diffrience in connecting through Dialup and GPRS....
thanks
A question about Dial up and Browser
I think your problem is that you need to define an internet access point (a WAP access point will not work), with the IP address at 0.0.0.0
Webviewer will alsways ask you for an access point, so you simply choose the one you configured
Paul
hmmm like my wap acess point is ufone.pkwap so how do i get to find out the internet access point??
could u pleease tell me ^_^
because i cant used webviewer and doris browser 😞
help would be really appriciated
You could try ringing the Nokia Helpline for your country, & ask for help configuring an internet access point. They're pretty good like that.
Also, there is some information on reqwireless's website about how to configure the access point
The nokia helpline in my country hmmmmm I doubt they will be able to help me because they hardly help anyone because this is pakistan i live in and everything here is messed up.....
Ill check reqwireless's website ...but ur help would be better i would think :P
Any Idea how i can find out my internet acess point??
ring your mobile operator, they should be able to tell you. If you see the list on Reqwireless's page, you'll see they are normally quite obvious. For example mine is movistar.es (movistar = my operator, in Spain...)
best of luck Paul
ok i got it thanks alot 😉
