how to lock the kepad without using the kepad.
11 replies · 3,219 views · Started 18 February 2003
I want to know of a way to engage the kepad lock by using the joystick\2 buttons.
My keypad slder is already weak and each time unlock the keypad I don't want to move the keypad slider up and down to re-lock it.
press the on/off button gently, and push the joystick upwards, then select
(at least that's what I used to do, the block keyboard was the last option on the list, after the profiles - but it's not there any more!!!) I just installed autostart to trial it - any ideas anyone????
Paul
Thanks Walda. That's very intelligent of the programmers - a dynamic menu dependent on if the phone is open or closed.
Well done (again) Psiloc! 😃
Paul
[quote="liverpool lad"]Thanks Walda. That's very intelligent of the programmers - a dynamic menu dependent on if the phone is open or closed.
Paul[/quote]
What have psiloc got to do with this? This is just a feature of the Nokia 7650. I have no psiloc software installed and mine does this :?
oops 😮ops: I had not come across this feature with the standard Nokia soft. Yr right Gaz
so, to rectify... well done Nokia (?)
Paul
[quote="PURPLEMUSTANG"]I want to know of a way to engage the kepad lock by using the joystick\2 buttons.
My keypad slder is already weak and each time unlock the keypad I don't want to move the keypad slider up and down to re-lock it.[/quote]
You can also make the "Lock keypad?"screen appear by placing a magnet over/nearby the menu button! 😊
The normal way for the phone to find out that it's closed,is in fact a magnet placed in the keypad-part of the phone...So,what you do here is just confuse the phone to think that it's closed.. 😊
Allthough,when you remove the magnet again,it thinks it's open again,so it also unlocks the keypad... :/
oops.I have a german manual and since I don't speak german I didn't know about this function.well I am fully happy now.
again for those who want to lock the phone without the slider.
1-press the on/off button
2-press up once
3-press the joystick button.
Perhaps you may want to install a 3rd party app like that SeleQ. It's have a auto lock keypad function. 😃
