Im using e90 but when i click the "connect to internet" from pc suite 7 via usb cable, there is an i error i received like this one "one touch access failed to establish a network connection. Please check the connection settings." I do some phone checking.
1. I have received the config settings from my network provider and its running on my e90.
2. I have installed Nokia PC Suite 7 and there is no problem with my usb connection and can able to detect my phone.
3. I also check the internet connection setting on my phone and make sure that my access point was set to my network provider.
But still i cannot able to connect laptop to the internet using my gprs.
When I first tried it on my e90 it didn't work. Aftera hard reset it worked fine. Make sure you backup your phone first though.
I have mine working fine under Linux as well but only via cable. I can't get it working over Bluetooth as yet
[QUOTE=Rower;401347].
QUOTE]
I think you need choose the correct usb moderm in NOkia PC suite use the button:
connect to internet-setup-choose a usb moderm
hello, thanks for the reply, i already tried hard resetting but no success. and also i chose the usb modem and still not working. is it possible that my nokia pc suite not compatible?
pls help, still cannot connect to the gprs through my laptop. :frown:
What about your networkprovider ? Do they probably disable the connection when a laptop is used on the GPRS ?
😊 Good luck : jApi NL
are you using a cable or bluetooth?
Try to edit the connection and set it up manually. I mean do select country and edit your internet access poin and if required username and password.
thanks for your post, im using cable. and it doesnt work also, i already check my provider and no problem. and i tried to you my friends laptop n it work, problem is on my laptop, it doesnt. :con?
