Hey!
I have a problem with the music player directory in N95.
at the list of "artist"/"Album"…the names their never updating after deleting a song - it mean after transferring a new song to the phone I can see his details under "artist"/"album" directory but if I will delete this song I will still show his details under "artist"/"album" directory but without a song and I cant delete it.
Doing reset, refresh, didn't help.
music player directory problem
i have the similar prob with my n95 classic.. i still have no clue how to fix it..
Hello to you both. Solution is as follows:
1) Connect the phone in "Data transfer" mode to your PC.
2) Delete the two files in "E:\private\101FFC31" (called "mpxv1.mpd" and "pcv5.mpd"😉.
3) Delete the one file in "E:\private\101ffca9" (called "harvesterdb.dat"😉.
4) Disconnect the phone from the PC and run the Music Player on the phone.
5) Wait a while for the app to startup. It will be rebuilding the library......
6) Just to be sure, select "Refresh".
GordonShowers wrote:Hello to you both. Solution is as follows:1) Connect the phone in "Data transfer" mode to your PC.
I tried both: Does not work... I also noticed that my profile changed. VIRUS? I Scanned with the one from nokia website but nothing shows up. I did dnload a flash file prior to this problem...weird.
