Hi folks
Does anyone know if it's possible to sync calendars 'online' between an N95 and 6500 Classic? I know the N95 is Symbian, and I don't think the 6500 Classic is. I know I can send appointments via Bluetooth between the phones, but is there an easier way of doing this using maybe an online service from Nokia, using GPRS or WAP?
Basically I want to be able to put an entry in my calendar and have it appear on my girlfriends phone.
Cheers :icon14:
Yes, you can. I used to do exactly that!
On the N95, run the Switch application. Select the Send option, and take it from there. I used bluetooth.
You can then save it so it'll remember your settings, and in future just one click will sync every time.
GordonShowers wrote:Yes, you can. I used to do exactly that!On the N95, run the Switch application. Select the Send option, and take it from there. I used bluetooth.
Ooooh, good idea! I've used Switch before when I got a new handset, never thought of that. I'll give it a try tonight when I get home, thanks! :icon14:
