N81 8GB V21 Firmware Now available for all product codes via NSU
12 replies · 14,356 views · Started 21 November 2008
is this new firmware unstable as i have not been able to get my phone updated. still on v11. i changed to a generic product code to remove my vodafone branding but i cant find a product code that will allow an update to v21.
V21 should be available to all product codes.
Where are you located.?
My Product Code is 0544169
i can confirm that im in the UK aswell using the same code that ends in 0544169 i updated back in november
no problems bar crap phone memory (7mb at all times - no apps running)
i just tried to update it again/see if there is another update and its saying there isnt as the newest is 21.0.008 using the newly updated (to me neway 😛) v1.4.85 NSU
Ash
then i dont understand. i just checked again and it says the latest firmware for 0544169 is 11.0.045
very frustrating.
i dont see the point tbh of a hard reset. i checked on nokias own site, and it shows the latest firmware for 0544169 as v11.0.045.
This is normal because nokia withdrew version 21.0.008 very instable .so the last firmware for N81 8GB is 11.0.045
